Integration - Custom HTTP Delivery issues with AWS NLB
Ok so I'm trying to setup a custom http delivery to an Event-Driven Ansible webhook. The EDA target is in AWS behind a network load balancer where SSL terminates on the ec2. For sake of argument let's assume everything on the AWS side has been done; sec group with LM's public IP's, no bad NACLs, NLB is interface-facing, public DNS is good, etc.
So I can test the webhook using curl from an internal and external host, and it's successful!
But testing from LM ends in nothing but a request timed out.
I do not know if it's TLS/SSL related..
Is it DNS? Like can LM correctly resolve my fqdn?
Is it some LB attribute like preserve client ip's?
Here is the URL in question, sanitized:
I did set the method to POST, included the user and passwd and a very simple Raw payload of {"message": "HELLO"}
Skeer
OPI might not have been super clear earlier.. so the only way I am able to test this right now is using the Test Alert Delivery function. I know there's ways to return data in the HTTP response but I am nowhere near being able to do that right now.
Last year when I was setting up the Integration from LM to Jira.. the Test Alert Delivery was all I needed. I assumed I could get by using mainly/only it this time.
And the Integration logs show 'failed to parse' under external ticket ID, and the log details show the entire HTTP response as: "Timeout received waiting for HTTP Response". And to reiterate from earlier, I do not have the Include an ID provided.... checkbox checked.
I mean that LogicMonitor might be waiting for a different kinda response. Like try returning some basic json like {"TicketID": "12345"} and see if that times out still. Also what happens when you click on the Test Alert Delivery in LM?
Can you show us screenshots of the test and/or the integration log?
Skeer
OPNope, I did not check that box. The rulebook I'm using either prints HELLO if the message contains that as it's value, or prints the entire payload if message != HELLO.
So as far as I know, it's not waiting on anything. When I test using curl, there are no time outs.
I don't know anything about Ansible webhooks but perhaps LM is timing out because it's waiting for a specific response back? Like do you have the "Include an ID provided in HTTP response" enabled? If so, you want to include that json key into your response back.
Skeer
OPOk so I might have jumped the gun above.. so turns out removing the trailing slash now allows LM to reach the endpoint but I get a 404 returned.
<html> <head><title>404 Not Found</eda-event-streams/title></eda-event-streams/head> <body> <center><h1>404 Not Found</eda-event-streams/h1></eda-event-streams/center> <hr><center>nginx</eda-event-streams/center> </eda-event-streams/body> </eda-event-streams/html>
So without the slash, LM reports a 404, the endpoint a 301. With the slash endpoint reports a 200, but LM a timeout.
Skeer
OPOk well nevermind I guess, turns out the trailing / in the URL is what was breaking this.
Ugh
