'Instance not found' output manipulation
Is it possible to have ‘Instance not found’ be shown as something else, e.g.
Those 2 are:
I know I can do some logical stuff with a virtual data point but not sure what syntax to use in the expression specifically for ‘Instance not found’; this doesn’t appear to be treated the same as NaN using ‘un’.
Thanks
ldoodle
1 comment
tswisdom
·2 years agoHello @ldoodle,
Unfortunately as of this moment it’s not possible to adjust the message displayed when the filters configured in a given widget do not match any instances in your portal. If you’d like the option to provide an alternate message, I’d suggest submitting feedback through your portal requesting the option, to be considered by our product managers for future development.
