I need to alert for 20 consecutive failed logon attempts within a 30 minute time period
We have a team that would like to get alerted on 20 consecutive failed logon attempts from a single account on any of our SQL servers in a 30 minute time frame. I started out using the eventsource for errors in the security event log and set it watch for EventID 4625. I am not very savvy with groovy and am now looking at setting up with a Powershell script via a new Datasource but I am having some trouble with it. If anyone has any ideas on how to best script this I would greatly appreciate the help!
Will_Pratt
Posted 3 years ago·Last reply 1 year ago
9 comments
Cole McDonald
·1 year agoMore info: Verifying the changes in the environment... this seems to have only affected the local groups on the utility server itself. The domain group affiliations don't seem to have been touched. I would therefore also gather that it isn't making those local changes on the 20-30 devices in my test environment... (Confirmed)... so this script doesn't make the necessary changes in the domain. Let me verify I'm reading the right part of the deployment KB... also verified. The script as presented doesn't do the tasks correctly for a domain user.
Cole McDonald
·1 year agoSeparate counts for the substatus can show service account passwords expiring vs Dictionary attacks vs username scans as well. Here's a list of substatii for reference: Netlogon Error Codes Code Definitions (eventsentry.com)
Shack
·1 year agoWill the complex filter option within an event source let you script a number of occurrences value or is it still just for basic filtering?
I don't have LM Logs but would like to be able to account for a a bunch of consecutive failed logons but ignore when it occasionally happens.
Cant use PowerShell unfortunately.
·1 year agoNot with the filter option built in. But you could use the script cache to remember the last few polls and get a rolling sum of failed logins. It's more of a datapoint, but then you'd alert whenever the failures surpassed your threshold.
·2 years agoInstead of cloining the DS, have the eventLog, eventID and timeSpan set as instance level properties on a multi-instance datasource. To create the instances with their ILPs, create a property that lists them all out:
Then your discovery script would look like this:
With the above example, this would create the following instances:
Note this discovery script replaces the pipe and space characters in the instance to create the wildvalue.
Cole McDonald
·2 years agoWe use these all the time. Using $events.count as the return value:
(note the use of backticks for line continuation)
At the top of the script is this:
This allows easy cloning and quick set of the data being pulled… then you can set normal thresholds and heads/tails (consecutive polls to raise/lower the alert).
Edward Garza
·2 years agoIf the SQL logs are ingested into LM Logs and the failed SQL login attempts are logged, then yes, you can set a log alert to notify when 20 failed SQL login attempts are seen in the log files within a 30 minute period.
·3 years agoI wonder if LM Logs and the aggregate functions might be able to accomplish this. Worth reaching out to your CSM to see if you can get a technical resource from LM to investigate whether or not this would be possible. LM Logs and APM are big pushes right now, so if they have a real use case they can use their shiny new features to solve, they might be motivated to help.
·3 years agoLogicMonitor has not shown any intent to add this sort of alert logic -- I know I have requested it for many years and seen nothing on the roadmap. It would be wonderful in many places, like "high CPU for N of the last M minutes", etc.
For events in particular, there is nothing if you use the normal event matcher. If you use Groovy, you might be able to leverage Collector Script Caching to track the events seen and only generate an event from the Groovy code if the your conditions match. I believe the cache is bound to specific collectors (not distributed), so if you use load-balanced collector groups I imagine it will end badly.
