How can I import a bunch of websites?
The documentation just says to import a JSON file, but I don't see anything about how to format said JSON file. Does anyone have any more information on how I can format a file to import a bunch of Internal URLs?
https://www.logicmonitor.com/support/websites-management#h-importing-a-website-check-from-file
If anyone from LM sees this, please add an Example file or something to the above pages. :)
Kel L
5 comments
Michael Rodrigues
·1 year agoIt's more meant as an Export/Import than a raw import like Netscan CSV.
Admine provided the structure, but I'll include some screenshots to point out where export is:
Select a website, click the Manage gear in the top right.
Click "Export" button on the bottom right.
Admine
·1 year agoThis would be the structure 😃
Daniel Blanco
·1 year agoDid anyone find the website base json file that can be used to import massive amount urls to monitor?
The support page for Website monitoring ( https://www.logicmonitor.com/support/websites-management ) doesn't provide the JSON file example and Joe_Williams where is the 'export' option in LM \ Websites?
David Bond
·1 year agoKelemvor - this is easily scripted. Please DM me a sample spreadsheet (3 lines would do and the data can be fake) and I'll knock something up for you.
Joe Williams
·1 year agoI agree sample files, like with the netscan csv would be nice.
You could add an example website into monitoring, and then export it. You would then have a base file for manual importation.
Personally I would add a sample, and then use the API to duplicate the object adjust what I need then post a new website through automation.
