Historical SDT en reporting
Hi community,
I'm running into a limitation with reporting on Scheduled Downtime (SDT) in LogicMonitor. Right now, i' m able to pull alerts that occurred during SDT' s but i cannot generate a single report that shows all historcal SDTs across all my resources/devices.
For my use case, it's important to:
- Filter per resource group
- Include this data in regular reporting and analysis to highlight structural SDT usage
My questions to the community:
is there any way to generate such a historical SDT report, does someone have a script or code to share to get that trough the API
Thanks in advance!
Admine
Posted 1 year ago·Last reply 11 months ago
1 comment
Ian Marge
·11 months agoHello Admine,
Yes, you can use the SDT Inventory report to list historical SDTs across resources, including filters like Resource Group, and even schedule it for regular delivery.
For automation, you can also retrieve SDTs via the REST API, either by running the SDT Inventory report programmatically or by querying SDT endpoints directly.
See docs for details:
Hope that helps.
Best,
Ian
