Help with Groovy Script for DNSSEC monitoring
There is currently no LogicModule for monitoring DNSSEC. I am trying to create a custom datasource using groovy in order to test DNS utilizing a dnssec key. Problem is, I don't have java/groovy experience.
I have set 3 properties on my collector device as follows: dns.resolvers: 8.8.8.8, dns.seckey: <super secret key>, dns.testname: <fqdn.com>
The only thing I really know how to do at this point is to define each of these properties at the beginning of the script as follows:
import org.xbill.DNS.*;
def dnsServers = hostProps.get('dns.resolvers');
def dnsNameToResolve = hostProps.get('dns.testname');
def dnsSecurityKey = hostProps.get('dns.seckey');
Has anyone written anything for this purpose? Any ideas on what I need to do here?
CaseyW
OP4 years agoMuch appreciated, thank you for the resources!
·4 years agoI am not positive you need to store the private key to monitor, but perhaps it can help - I have not tried this myself before. You probably want to start with some examples like these (Java not Groovy, but should be fairly simple to use for Groovy development):
https://www.javatips.net/api/org.xbill.dns.dnssec.dnssecexception
https://github.com/adamfisk/DNSSEC4J/blob/master/src/main/java/org/littleshoot/dnssec4j/DnsSec.java
Certainly not usable as-is, but good ideas on how to accomplish the goal.
