Groovy script failing for alinux server
We have a groovy script which is working fine for a data source. However when we are trying to run the same in debug mode, it’s failing. Can someone help on this.
sprusty
6 comments
sprusty
OP3 years agoThank you it worked.
Kirby_Narine
·3 years agoIf it’s working via datasource test, but not in debug (!groovy), can you make sure the hostprops are being populated correctly via debug? Consider manually entering them in the script as you run it via !groovy:
host = "HOSTNAME"
user = "SSHUSERHERE"
pass = "SSHPASSHERE"
port = hostProps.get("ssh.port")?.toInteger() ?: 22
cert = hostProps.get("ssh.cert") ?: '~/.ssh/id_rsa'
Note: For hostname, make sure to use the same value under INFO tab of device for system.hostname.
If still failing, definitely create a support ticket, as it can be tested more in-depth from LM support side.
Joe Williams
·3 years agoYour return of your command begin ran is returning nothing. You can’t trim nothing. That is basically what your error is.
sprusty
OP3 years agoThe script :
import com.jcraft.jsch.JSch
import com.santaba.agent.util.Settings
import java.text.SimpleDateFormat
import static groovy.io.FileType.FILES
import static groovy.io.FileVisitResult.*
import groovy.time.TimeCategory
import groovy.json.*
host = hostProps.get("system.hostname")
user = hostProps.get("ssh.user")
pass = hostProps.get("ssh.pass")
timeout = 15000 // timeout in milliseconds
def date = new Date() //Get Current date stamp
def sdf = new SimpleDateFormat("MM/dd/yyyy HH:mm:ss") //format the date for later use in the event generation
def _outArray = []
command = ("ps H -u mqm | wc -l")
def command_output = getCommandOutput(command) //run the command on the host
command_output = command_output.trim() //the output is in string format and has multiple blnk lines, clean up blanks
command_output.eachLine //for each of the lines in the command output
{ line ->
int _line = line as int //convert output to integer, this is the file count of older files if any exists
if (_line>19000){ //if there are older files
println _line
else{
println _line
return 0;
// DO NOT Change anything below this line
* Helper method which handles creating JSCH session and executing commands
* @return
def getCommandOutput(String input_command) {
try {
// instantiate JSCH object.
jsch = new JSch()
// do we have an user and no pass ?
if (user && !pass) {
// Yes, so lets try connecting via cert.
jsch.addIdentity(cert)
// create session.
session = jsch.getSession(user, host, port)
// given we are running non-interactively, we will automatically accept new host keys.
session.setConfig("StrictHostKeyChecking", "no");
String authMethod = Settings.getSetting(Settings.SSH_PREFEREDAUTHENTICATION, Settings.DEFAULT_SSH_PREFEREDAUTHENTICATION);
session.setConfig("PreferredAuthentications", authMethod);
// set session timeout, in milliseconds.
session.setTimeout(timeout)
// is host configured with a user & password?
if (pass) {
// set password.
session.setPassword(pass);
// connect
session.connect()
// execute command.
channel = session.openChannel("exec")
channel.setCommand(input_command)
// collect command output.
def commandOutput = channel.getInputStream()
channel.connect()
def output = commandOutput.text;
// disconnect
channel.disconnect()
return output
catch (Exception e) {
e.printStackTrace()
// ensure we disconnect the session.
finally {
session.disconnect()
the error in debug mode:
$ !groovy
Error when executing the script -
output:
exception:Cannot invoke method trim() on null object
java.lang.NullPointerException: Cannot invoke method trim() on null object
at org.codehaus.groovy.runtime.NullObject.invokeMethod(NullObject.java:91)
at org.codehaus.groovy.runtime.callsite.PogoMetaClassSite.call(PogoMetaClassSite.java:47)
at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:47)
at org.codehaus.groovy.runtime.callsite.NullCallSite.call(NullCallSite.java:34)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:120)
at Script759.run(Script759.groovy:20)
at com.santaba.agent.util.GroovyScriptShell.execute(GroovyScriptShell.java:126)
at com.santaba.agent.util.GroovyScriptExecutor.execute(GroovyScriptExecutor.java:129)
at com.santaba.agent.debugger.GroovyTask._executeInAgent(GroovyTask.java:207)
at com.santaba.agent.debugger.GroovyTask._handle(GroovyTask.java:186)
at com.santaba.agent.debugger.DebugTask.run(DebugTask.java:165)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.base/java.lang.Thread.run(Thread.java:829)
Joe Williams
·3 years agoAn output of the failure and the code itself would help us help you.
