Filter within a widget
I have a custom datasource for some specific SQL metrics. Presently the collection script is explicitly excluding system databases (master, model, tempdb etc.) with a WHERE clause.
I'd like to re-include these system databases but have them on their own widget (with the current widget excluding them). Only way I can think of is a duplicate datasource that simply reverses the WHERE clause, but this seems way overkill.
Can we filter per-widget?
ldoodle
3 comments
jake_nahm
·1 year agoHi ldoodle, My name is Jake Nahm, and I am part of LogicMonitor's Product team. This seems like a really interesting use case for a feature that is currently in development. If you are open, I would be happy to talk through the details live.
ldoodle
OP1 year agoand
Lewis_Beard
·1 year agoThe only things I can think of would be:
Ideally, one day LM would support both resource and instance property filters on all widgets. If they ever had that, then we could do these kinds of things cleanly. In this future hypothetical, you could put an auto property source in the code on your instances, make the datasource multi-instanced, make instance groupings based on the instance property, AND use the instance property in the widget.
But I dont think they are there quite yet.
