exception:groovy.lang.MissingMethodException: No signature of method:
Working on my NetScan script for our Arista AP's still and when trying to execute a http [DELETE] I get the above error when following the Delete documentation here which suggests I can just call the URL and header.
Currently this is just using the collector debug !groovy command
If I then try with blank payload I get a different error: exception:java.lang.NullPointerException
First Error with no payload in call:
exception:groovy.lang.MissingMethodException: No signature of method: com.santaba.agent.groovyapi.http.Client.delete() is applicable for argument types: (java.lang.String, java.util.LinkedHashMap) values: [https://awm14001-c4.srv.wifi.arista.com/wifi/api/session, [Content-Type:application/json, ...]]
Possible solutions: delete(java.lang.String, java.lang.String, java.util.Map), release(), release(), close(), every(), get(java.lang.String)
java.lang.RuntimeException: groovy.lang.MissingMethodException: No signature of method: com.santaba.agent.groovyapi.http.Client.delete() is applicable for argument types: (java.lang.String, java.util.LinkedHashMap) values: [https://awm14001-c4.srv.wifi.arista.com/wifi/api/session, [Content-Type:application/json, ...]]
at com.logicmonitor.groovy.objects.BaseWrapper.invoke(BaseWrapper.java:124)
at com.logicmonitor.groovy.objects.lang.ScriptWrapper.run(ScriptWrapper.java:31)
at com.santaba.agent.groovy.executor.GroovyScriptShell.execute(GroovyScriptShell.java:71)
at com.santaba.agent.util.GroovyScriptExecutor.execute(GroovyScriptExecutor.java:148)
at com.santaba.agent.debugger.GroovyTask._executeInAgent(GroovyTask.java:210)
at com.santaba.agent.debugger.GroovyTask._handle(GroovyTask.java:189)
at com.santaba.agent.debugger.DebugTask.run(DebugTask.java:176)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.base/java.lang.Thread.run(Thread.java:829)
Caused by: groovy.lang.MissingMethodException: No signature of method: com.santaba.agent.groovyapi.http.Client.delete() is applicable for argument types: (java.lang.String, java.util.LinkedHashMap) values: [https://awm14001-c4.srv.wifi.arista.com/wifi/api/session, [Content-Type:application/json, ...]]
at org.codehaus.groovy.runtime.ScriptBytecodeAdapter.unwrap(ScriptBytecodeAdapter.java:71)
at org.codehaus.groovy.runtime.callsite.PojoMetaClassSite.call(PojoMetaClassSite.java:48)
at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:47)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:136)
at Script85.run(Script85.groovy:76)
at jdk.internal.reflect.GeneratedMethodAccessor68.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at com.logicmonitor.groovy.objects.BaseWrapper.invoke(BaseWrapper.java:118)
... 9 moreSecond Error with Blank Payload:
java.lang.RuntimeException: java.lang.NullPointerException
Caused by: java.lang.NullPointerException
at com.santaba.agent.groovyapi.http.Client._processResponse(Client.java:580)
at com.santaba.agent.groovyapi.http.Client.request(Client.java:429)
at com.santaba.agent.groovyapi.http.Client.delete(Client.java:409)
at com.santaba.agent.groovyapi.http.Client$delete$4.call(Unknown Source)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:144)
at Script91.run(Script91.groovy:76)
... 9 moreThe Code:
* Arista WIFI Integration with CUE for discovery of the AP's
import com.santaba.agent.groovyapi.http.*
import com.santaba.agent.groovy.utils.GroovyScriptHelper as GSH
import com.santaba.agent.AgentVersion
import java.text.DecimalFormat
import groovy.json.JsonOutput
// To run in debug mode, set to true
Boolean debug = false
// To enable logging, set to true
Boolean log = false
// Set props object based on whether or not we are running inside a netscan or debug console
def props
try {
hostProps.get("system.hostname")
props = hostProps
debug = true // set debug to true so that we can ensure we do not print sensitive properties
catch (MissingPropertyException) {
props = netscanProps
//String key = props.get("AristaWIFI.api.key")
//String token = props.get("AristaWIFI.api.token")
//String clientId = props.get("AristaWIFI.api.clientId")
String key = [REMOVED]
String token = [REMOVED]
String clientId = "logicmonitor"
//if (!key) {
// throw new Exception("Must provide AristaWIFI.api.key to run this script. Verify necessary credentials have been provided in Netscan properties.")
//if (!token) {
// throw new Exception("Must provide AristaWIFI.api.token credentials to run this script. Verify necessary credentials have been provided in Netscan properties.")
//if (!clientId) {
// throw new Exception("Must provide AristaWIFI.api.clientId credentials to run this script. Verify necessary credentials have been provided in Netscan properties.")
//def logCacheContext = "${org}::arista-wifi-cloud"
//Boolean skipDeviceDedupe = props.get("skip.device.dedupe", "false").toBoolean()
//String hostnameSource = props.get("hostname.source", "")?.toLowerCase()?.trim()
Integer collectorVersion = AgentVersion.AGENT_VERSION.toInteger()
// Bail out early if we don't have the correct minimum collector version to ensure netscan runs properly
if (collectorVersion < 32400) {
def formattedVer = new DecimalFormat("00.000").format(collectorVersion / 1000)
throw new Exception("Upgrade collector running netscan to 32.400 or higher to run full featured enhanced netscan. Currently running version ${formattedVer}.")
externalHost= "awm14001-c4.srv.wifi.arista.com";
httpClient = HTTP.open(externalHost,443);
httpClient.setHTTPProxy('proxy.iggroup.local',8080);
// Log in to arista
loginurl = "https://awm14001-c4.srv.wifi.arista.com/wifi/api/session"
payloadstring = '{"type":"apiKeycredentials","keyId":"'+key+'","keyValue":"'+token+'","timeout":3600,"clientIdentifier": "'+clientId+'"}';
def payload = payloadstring;
println payload;
def loginResponse = httpClient.post(loginurl,payload,["Content-Type":"application/json"]);
if ( !(httpClient.getStatusCode() =~ /20/) )
// Error has occured
println "Authentication Failure";
println httpClient.getStatusCode();
println loginResponse;
return(1);
String RawCookie = httpClient.getHeader("Set-Cookie")
//Have Kept but as yet not needed will remove if not needed..
String httpResponseBody = httpClient.getResponseBody()
//Retrieve the Cookie to use from the header.
AristaCookie = RawCookie.split(';')[0]
String cookieString = '"'+AristaCookie+'"'
def logoutheaders = ["Content-Type":"application/json","Cookie":cookieString]
//println logoutheaders
def logoutResponse = httpClient.delete(loginurl,logoutheaders) <- With No payload
def logoutResponse = httpClient.delete(loginurl,'{}'logoutheaders) <- With blank payload I have just tried "" as the payload as well.
logoutResult = httpClient.getStatusCode()
//Error has occured
println "Logout Failure";
return(1);
println AristaCookie;
println httpResponseBody;
println logoutResponse;
def LMDebugPrint(message) {
if (debug) {
println(message.toString())
}The Same URL and the same header with no payload works if I work in python obviously appreciate they are different languages, just confirming that the formatting is correct.
SteveBamford
4 comments
SteveBamford
OP1 year agoFurther to this, as I now have NetScan script running externally, I am now on the discovery and collector scripts so need to revisit this, as such I have looked at the client documentation and tried to build the correct response.
I now get
at com.santaba.agent.groovyapi.http.Client$delete$5.call(Unknown Source)
at Script660.run(Script660.groovy:96)
at jdk.internal.reflect.GeneratedMethodAccessor82.invoke(Unknown Source)
... 9 more
The issue here is that there is no content in the delete as it is the cookie you are deleting, I have a workaround in reducing the time the session is open, however this could end up with multiple sessions open on the end point unnecessarily until they time out.
SteveBamford
OP1 year agoJust as a side note, I can work around this by reducing the session timeout from an hour to say 10 minutes when logging on which would work.
Justin Rider
·1 year agoIt looks like the http Delete method takes 3 parameters (uri, data, headers):
Client (collector API)
SteveBamford
OP1 year agoI tried a number of methods, in the end I couldn't get it to work, so gave up and switched over to using Python for the discovery script, and I will utilise groovy for the collection scripts in due course.
