Enable Monitoring for Latch/Lock
Hi Team,
In LM under datasource "SQL Server Global Performance" >> under port >>there is 1 graph latch/lock , how can we enable monitoring for this. please Support
Regards
Learner
3 comments
·4 years agoOk, when you select the MSSQLSERVER(port-1433) instance and see all the graphs on the right hand side, do the other graphs have data? If so, the problem is a single datapoint. If not, the problem is likely authentication.
·4 years agoI think you may have answered your own question. You should probably reach out to support for this kind of thing. The community is a great place to find help with things, but we are not technical support.
As to your question, I'm not sure. I'd need more details. What's the datasource name? What datapoints figure into that graph? Are you successfully monitoring your SQL server for other metrics?
