Eaton UPS support
Anyone able to confirm that LM fully supports Eaton UPSes out-of-the-box? Someone who has their equipment?
I'm aware of the two datasources "Eaton_UPS_Temp" and "Eaton_UPS_Remote_Environment" but these only cover environmental (temp/humidity). I suspect that Eaton power monitoring is covered by the generic "UPS Status" and/or "UPS Output Lines-", otherwise it would make no sense that LM would only provide environmental and not power monitoring, but wanted to actually confirm this. These generic datasources don't have documentation and LM support is not able to verify if they would be used or not.
I'm sure I can write my own custom check if needed, but wondering if someone with the equipment can confirm built-in support either way. Thanks!
R_W_D
I was just curious if you had written anything custom that it working ?
OPI didn't. I don't think we ended up monitoring any Eaton UPSes in LM so I still don't know if it would be covered by the generic UPS check. If you have any you want to monitor in LM, I would suggest just try adding them and see if the generics get applied.
