Dynamic Dashboards
Tokens are one of the most powerful aspects of LogicMonitor's dashboards. They make it possible to easily change the subject matter of an entire dashboard (or a group of dashboards).
A question that comes up from time-to-time is if it's possible to dynamically update a dashboard using a drop-down menu on the dashboard itself instead of having to edit the dashboard. While there are some exciting changes coming to LogicMonitor's dashboards in the future, I wanted to see if I could come up an option that works today. The end result is a solution that allows dynamically choosing token values for groups, resources, and/or instances directly from the dashboard itself. It turned out to be a great demonstration of what's possible using LogicMonitor's API.
Assuming your dashboard is designed to take advantage of tokens (like all the bundled dashboards are), then this selector makes it easy to quickly flip between different contexts. Refer to the Creating Dashboards support article for more info on using dashboard tokens.
Some good use-cases for this dynamic selector:
- Switching between different MSP customers.
- Flipping to different cloud subscriptions or vCenters.
- Flipping between facilities, datacenters, or environments (prod, dev, QA, etc.).
Below is a link to a sample dashboard that's a variant of LogicMonitor's bundled Windows dashboard but with two new widgets: a "Resource Selector" widget and a "Read Me" text widget that describes how the selector works. The resource selector is just a normal Text widget but with some JavaScript embedded that leverages the LogicMonitor API to populate the drop-down menus and update the dashboard's tokens as appropriate.
Dynamic_Dashboard_-_Windows.json
To use the above dashboard, save the linked JSON file to your local workstation, then in your LogicMonitor portal go to Dashboards and click Add > From File. Configuring the widget can be done through dashboard tokens. The tokens mentioned below will determine which dynamic drop-downs are displayed. For instance, if no 'defaultInstance' token is defined then the Instance drop-down won't appear. Refer to the token descriptions below for more details.
Required Tokens:
- 'defaultResourceGroup': a common token used by the widgets on the dashboard. The 'Resource Group' drop-down menu will update this token upon clicking Go.
- 'apiID' & 'apiKey': a LogicMonitor API ID and secret key used for REST API calls. Note: there's a place near the top of the Resource Selector's Javascript source where you can optionally hard-code these two values instead of more openly exposing them in a token.
Optional Tokens:
- 'defaultResourceName': (optional) a common token used by widgets on a dashboard for specifying the resource(s) to show data for. The 'Resource' drop-down menu will update this token upon clicking Go. If the token isn't defined then the script will hide the 'Resource' menu under the assumption that it's not being used on this dashboard.
- 'defaultInstance': (optional) Token used by widgets on a dashboard for specifying instances to show data for. The 'Instance' drop-down menu will update this token upon clicking Go. Note that if you want to use the 'Instances' menu, it requires a named resource and a datasource to fetch instances for. If the 'defaultInstance' token or 'defaultDatasource' tokens aren't defined on the dashboard OR the 'Resource' menu is set to "*" then the 'Instance' menu will be hidden.
- 'dynamicGroupParentID': (optional) The numeric ID of the parent group you want to limit the dynamic group drop-down to. Will default to the root group (ID 1) if not specified.
- 'defaultDatasource': (optional) Name of a datasource that will be used for gathering instances that dynamically populate the 'Instances' drop-down menu.
- 'hideDynamicGroupDropdown' or 'hideDynamicResourceDropdown' or 'hideDynamicInstanceDropdown': (optional) can be set to "true" to force the 'Resource Group', 'Resource', or 'Instance' drop-down (respectively) to be hidden. This allows the widget to be flexible for choosing a group, a resource, an instance, or any of them.
Enabling the Sample Dashboard
In order for the selector to work with your LogicMonitor portal's API, you'll need an API credential that has "Manage" rights to the dashboard (so the dashboard's tokens can be updated) plus "View" rights to any groups & devices you want in the drop-downs. You can learn about creating API credentials here: https://www.logicmonitor.com/support/settings/users-and-roles/api-tokens
Aside from an 'defaultResourceGroup' dashboard token, you'll need to add two tokens to the dashboard specifying the ID and key of the API login you created. You can set these by opening the dashboard's Manage dialog and adding two new tokens: 'apiID' and 'apiKey' (note: these can be added at a dashboard group-level as well).
Other tokens you set on the dashboard will help determine behavior of the selector widget. For instance, if you set a 'dynamicGroupParentID' token containing a numeric ID of a resource group, then the selector will only show groups & resources under that parent group. Likewise, having a 'defaultResourceName' token will enable the Resource selector. Refer to the "Read Me" widget for full details on all the options.
So How Does This Work?
When the "Resource Selector" widget is first loaded, Javascript embedded in its HTML source makes a call to the LogicMonitor REST API to get a list of items to populate options in the appropriate drop-downs. The widget will auto-populate parent-child menus as appropriate. For example, when a new group is chosen in the 'Resource Group' menu then the 'Resource' drop-down list will auto-update to reflect what's inside the newly chosen group.
When the Go button is clicked, the widget's script does the following actions:
- 1. Calls LogicMonitor's [Get Dashboard](https://www.logicmonitor.com/support/rest-api-developers-guide/v1/dashboards/get-dashboards) REST method to get the current dashboard definition.
- 2. Loops through the dashboard's tokens retrieved during step #1 looking for 'defaultResourceGroup', 'defaultResourceName', and 'defaultInstance'. If found, it updates them in memory with the values chosen on the drop-downs (unless the respective field was set to be hidden).
- 3. Calls LogicMonitor's [Update Dashboard](https://www.logicmonitor.com/support/rest-api-developers-guide/v1/dashboards/update-a-dashboard) REST method to save the new token values.
- 4. Refreshes the page to reflect the new values.
How To Use This On Other Dashboards
Since the selector widget was designed to leverage tokens, applying it to another dashboard is as simple as cloning the widget to another dashboard and configuring any appropriate dashboard tokens (if not already set at the group-level).
Note: if you don't want to set your API ID and key as dashboard tokens, there's a spot you can set them inside the selector widget's source code instead. That allows you to hide them, especially if the user only has read-only privileges for the dashboard since they won't be able to edit widget's configuration. I'll post a follow-up comment on where to do that.
Kel L
·8 months agoI know this is really old but:
·2 years agoDoes this use v3 of the API? Is there an update to force it to use v3? v1/2 will be sunset "soon". Kevin_Ford
Cole McDonald
·2 years agoWe use this alot… I’d love to be able to use properties/tokens set at the group levels in the devices or to have a group structure I could apply properties that would get inherited so I could access my api keys more efficiently. I’d also like it to tie to a single user session rather than a global. I may have to see about changing ours over now that I have a bit more time to get back around to it. Changing the dashboard to look at a client environment makes everybody else using the same dashboard see the client I’m looking at once it refreshes. I’ve tried the checkbox that sounds like it should keep it local, but that doesn’t work either.
mmatec01
·2 years agoYeah, I would have never thought of that, but I do have that setting enabled, so the issue is elsewhere...But I am encouraged to hear it is working so I will keep troubleshooting.
Michael Raymond
·2 years ago@mmatec01 make sure your portal has the “Allow Scripts in Dashboard Text Widget” option enabled in Account Information > Portal Settings
And, of course, please do consider the security implications.
https://www.logicmonitor.com/support/portal-settings#h-configuring-the-logicmonitor-portal-settings
·2 years agoNo, i didn’t modify it in any way. I did set the tokens at the dashboard group level, but that’s the only “abnormal” thing about my setup.
@Kevin Ford mind posting that to a github repo? Would allow for better versioning control.
mmatec01
·2 years agoExcellent. I am using dashboard v1.9. Stuart, did you have to modify the underlying JavaScript or tweak it in any way in regards to API calls? Maybe I am missing something else to get it working?
·2 years agoI’m using it today successfully.
mmatec01
·2 years agoI would love to get this functionality in a dashboard. I downloaded the Dynamic Dashboard - Windows in json format, loaded in my LM instance (we are using Windows collectors) and - while Resource Selector is working fine - the dashboard is not being updated with selected resources. Question - is the underlying JavaScript compatible with LM API v.3? I assume "Update Dashboard" REST method to save the new token values is silently failing. Is anybody using this dashboard with success?
·3 years agoShould be able to. Just have to modify the code that displays a new selector, do a get for all website groups, and patch the appropriate token.
Kevin Ford
OP4 years ago@Rakzskull I just realized I missed your question about a Linux version of that dashboard. I've added the widget to our default Linux dashboard and made it available via this link. After you import the dashboard's JSON file into your portal (from the Dashboards list, click Add / From File), just edit the dashboard and enter your API ID and key into the appropriate dashboard tokens.
Rakzskull
·4 years ago@Kevin Ford Thanks for sharing this amazing customized feature. :)/emoticons/smile@2x.png 2x" title=":)" width="20" /> Do you have same for Linux one? if so then I would like to explore that one too :)/emoticons/smile@2x.png 2x" title=":)" width="20" />
alex_thornbury
·5 years ago@Kevin Ford This looks awesome and I am very interested in testing out what you put together here. However you mentioned in your first post "...there are some exciting changes coming to LogicMonitor's dashboards in the future...". Are these new features that presumably would make this easier present in LM version 150? If not, then are you allowed to give a timeframe as to when they will be?
Thanks and great job!!
Kevin Ford
OP5 years agoOne final note: Feel free to explore the selector widget's JavaScript code (accessed via steps 1 & 2 in my comment above). I tried to comment the code well to explain what each section does. I have no doubt that my code (especially the fetch statements) could be more efficient but it's functional. ?
Kevin Ford
OP5 years ago(Optional) Setting the API Credentials Inside the Code Instead of Dashboard Tokens
Setting API credentials in dashboard tokens may be a concern for some environments since there's no easy method for hiding those tokens. In those situations, you have the option of embedding the credentials directly in the selector widget's source code.
To do so:
1. Edit the widget by clicking its down-chevron and choosing Configure. You'll find that it's just a standard Text widget containing some HTML and quite a bit of JavaScript.
2. Click the Source button on the text editor's toolbar.
3. Scrolll down a bit until you get to the section specifying defining the 'apiID' and 'apiKey' variables. Enter your ID and key inside the quotes of the respective variables, then click Save & Close at the bottom of the dialog.
