Do you use SSO and require group membership? And does it also assign permissions?
Summary: Kel L initiated a discussion about using SSO with Azure and LogicMonitor (LM) to control user access and roles based on AD groups. Jan Garaj shared that enterprise environments typically use AD for managing roles and permissions across systems, suggesting a code-based management approach for larger user bases. SteveBamford endorsed the use of AD for role-based access, mentioning it reduces administrative overhead once set up and recommending maintaining a fallback username and password. Kel L expressed concerns about mapping Azure groups to LM roles and requesting guidance to avoid potential mistakes. Joshua Kurzawa asked for visual examples of how to map Entra groups to LM roles, as documentation is unclear. Overall, the discussion focuses on the integration of SSO with AD for streamlined role management in LogicMonitor.
We have SSO setup between LM and Azure. It's currently just wide open that anyone with an AD/Entra account can log into LM and get default Read-Only rights. However, I was asked to see about restricting access so that everyone would have to be in a certain LM Group in AD in order for them to get permissions.
I think I can figure that part out but I'm also wondering about assigning roles to people based on their AD group. In LM we have various Roles setup so people only have Edit rights to groups that they manage. Network Team has edit rights to the Network Equipment group, Database team has edit rights to the Database Servers group, etc.
I was originally thinking I'd use SSO just to grant base access and then I'd assign people to roles within LM that would set their permissions. Then I thought maybe I could create LM groups in AD for each team and have those grant access and handle the Roles people get assigned to. Just curious how many people utilize the role assigned from SSO thing and how well it works or if people just handle that within LM.
Thanks.
Dave Lee
·8 months agoWe have it setup the way you want. If you had groups in Entra ID to the Users/Group section on your App Registration, then configure the SAML claims to include the groups, then LM will get a list of the groups a user is in when they login.
As long as the names on the Roles in LogicMonitor match the names of the Groups in Entra ID, then it will automatically match users to the correct roles based on their Entra ID group membership.
Joshua Kurzawa
·8 months agoDoes anyone have a screenshot example how they've got Entra groups mapped onto LM roles (both from Entra Enterprise App and the Logic Monitor IdP configuration).
It's not explicitly clear on the support articles on how you conduct the matching without an example.
Kel L
OP9 months agoWe currently have SSO working but there's no restrictions on it. I found how we can restrict it to one group, but I'm not sure on using the groups in Azure to correlate to Roles in LM.
I was referred to this article, but I've never done this before so I'm not sure if I have to do everything on this page or not. Could anyone offer any guidance?
https://www.logicmonitor.com/support/single-sign-on
I think what we'd want to do is have Entra groups like LogicMonitor_NetworkTeam, LogicMonitor_DatabaseTeam, etc and then have those link with the Network Role and Database Role that we already have in LM which sets which resources they can view vs which they can manage.
I just don't want to break anything as I muddle my way through the above link, assuming it's correct.
SteveBamford
·9 months agoWe use AD for SSO and it works well with the permissions assigned to the role. The advantage here is once someone is assigned the appropriate role in AD there is no need to do any management within LogicMonitor other than tuning permissions within that role. I would always keep a fallback username and password should there ever be any issues with your SSO integration.
Migrating to AD Role based access control will reduce your administrative overhead once deployed. We set up the roles on deployment and other than adding new teams we have not had to worry about anything.
Jan Garaj
·9 months agoI would say authentication and authorization based on central role management (like AD) is the standard in the enteprise environment. User has roles/groups assigned in the AD and then all systems work with user AD roles/groups obtained during SSO (SAML, OIDC).
I can imagine that small user base can be managed manually within LM. But it will be pain/nightmare for bigger companies. I have around 70 "teams" and authorization is based on AD roles/groups. Everything is managed via code (Terrafom TF - which is not the strongest point of LM). TF detects current teams (they are not flat structure, but they have own level of organizations) and based on that creates for each team: LM role, LM dashboard/resource/report/website group. Of course each team has write access only to own team dashboard/resource/report/website group and read everywhere + write to "test" dashboard/resource/report/website group where teams can work together eventually.
