Delete many resources at once.
Is there a simple way of deleting many resources at one instead of having to go into each one and delete? Thanks!
kssox05
Posted 4 years ago·Last reply 2 years ago
5 comments
·2 years agoYeah, use a dynamic group to get them all into a group then delete the group. You’ll be prompted if you want to also delete the hosts in the group.
Joe Williams
·2 years agoLikely the easiest way is to move them into one or more groups, or creating a dynamic group containing them, then delete the group with the resources within them. You can also use the API to do bulk work. API will NOT place them in recently deleted though.
Group and delete group is what I came here to say.
More specifically, a Dynamic Group can work awesomely here if you can do an easy match to bring them all in.
Cole McDonald
dangerboy
·2 years agoMike , any other way without using coding or api can we delete bulk devices ? any easy way around ?
·4 years agoLikely the easiest way is to move them into one or more groups, or creating a dynamic group containing them, then delete the group with the resources within them. You can also use the API to do bulk work. API will NOT place them in recently deleted though.
