DataSource with PowerShell script
Hi everyone,
I would like to monitor AD Sync. The collector is on a Linux server, and the application is on a Windows one. I am trying to create a DataSource based on a PowerShell script, but I fund out I should set the config file of the collector with PowerShell. policy unrestricted. I don't wanna do this for security reasons. Not sure what else I can do to get that info. I would appreciate it if someone could give me some ideas. Thanks.
Evelyn Caviedes
4 comments
Joe Williams
·2 years agoYou are going to run into more problems than that with a Linux Collector. LogicMonitor doesn't let you use a PowerShell script via a Linux Collector. Generally, the easiest way to monitor Active Directory, is to install the collector directly on the Domain Controller.
Evelyn Caviedes
OP2 years agoThanks Joe, this is the easiest solution but I dont think I can do it. I hadn't noticed PowerShell is just available on Windows :O
