DataSource PowerShell Active Discovery and Collector scripts
Hello LM Community!
I am trying to configure a new DataSource that uses PowerShell scripts for both Active Discovery and Collector Attributes with the end goal being to populate the discovered devices/instances with data.
My Active Discovery script is as follows (I've left out the functions that generate bearer tokens and make the MS Graph calls).
$tenantID = '<tenantId>'
$appID = '<appId>'
$appSecret = '<appSecret>'
$appCredentials = New-Object System.Management.Automation.PSCredential($appID, (ConvertTo-SecureString $appSecret -AsPlainText -Force))
$authToken = Get-MSGraphAuthToken -Credential $appCredentials -TenantID $tenantID
$resourceURL = "https://graph.microsoft.com/v1.0/servicePrincipals"
$applications = (Invoke-MSGraphQuery -method GET -Uri $resourceURL -token $authToken -Recursive).value | Where-Object {$_.preferredSingleSignOnMode -eq "saml"}
foreach ($application in $applications) {
Write-Host "$($application.appId)##$($application.appDisplayName)"
}This successfully imports all of the instances as I would expect with their respective 'appId' and 'appDisplayName'. These can be seen under the Resources tab in LM.
My Collector Attributes script is as follows (again functions left out):
$appID = '<appId>'
$global:appCredentials = New-Object System.Management.Automation.PSCredential($appID, (ConvertTo-SecureString $appSecret -AsPlainText -Force))
$global:authToken = Get-MSGraphAuthToken -Credential $appCredentials -TenantID $tenantID
$todayDate = Get-Date
$expirationDate = $application.keyCredentials.endDateTime[0] | Get-Date -Format yyyy-MM-dd
$daysToExpiration = (New-TimeSpan -Start $todayDate -End $($application.keyCredentials.endDateTime[0])).Days
$data = [PSCustomObject]@{
appId = $application.appId
expirationDate = $expirationDate
daysToExpiration = $daysToExpiration
} | ConvertTo-Json
$data
}When I test this script, I select the Device to run it from and the Instance to run it against. The output contains the 'appId', 'expirationDate' and 'daysToExpiration' properties of all the instances, and not just the instance I want to match the latter two data points to. This would be as expected when looking at the script, but not what I want to achieve.
I don't understand how the Collector script is supposed to match the values of the properties to their respective Instances. Could someone please explain this to me?
I then want to interpret the output with a JSON parser, so I have some JSON Datapoints configured to pull in the desired 'expirationDate' and 'daysToExpiration'. For example:
Interpreter: JSON
JSON Path: $.daysToExpiration
This appears to only work for one of the properties but not both.
I have read other articles and documentation that mentions key pairs, but ideally I would like to stick with JSON.
Oliver_Kelsey
OP2 years agoI've made the suggested changes as well as setting Datapoints to use key-value pairs and the data is being imported as expected.
Is there any documentation that goes over all nuances and expected formatting when it comes to Active Discovery and Collector Attribute outputs, as well as Datapoint interpreters?
Thanks for the assistance, it's appreciated.
·2 years agoYep:
https://www.logicmonitor.com/support/logicmodules/datasources/active-discovery/script-active-discovery
https://www.logicmonitor.com/support/logicmodules/datasources/data-collection-methods/scripted-data-collection-overview
·2 years agoWithin your for loop, output one line for expirationDate and one for the daysToExpiration. Prepend each with the appId. So it would look like this:
123.expirationDate: 20240724
123.daysToExpiration: 20
456.expirationDate: 20250725
456.daysToExpiration: 21
Where 123 and 456 are the app IDs. Note, only integers/decimal numbers are accepted, so if you want the expiration date, you'll need to pull that in as an ILP during instance discovery.
