Creating a Complex Data Source to check the Interface Description and then the state of an interface to generate an alert.
The plan is on our switches we include "MO-CRIT" in the description if we want to generate an alert within LogicMonitor, it is fairly obvious to me that we need to create the datasource using Groovy which I have done, but when ever I run I get the following for the data source "Exception=No Such Property: output for class: Scriptnnn
I have set up the variable name IntName and have tried the system.instanceDescription and the auto.interface.alias nether seem to work
def IntName=taskProps.get('system.instanceDescription') (I have tried instanceProps.get)
Any suggestions.
SteveBamford
2 comments
SteveBamford
OP4 years agoGreat followed this through and looks to be working, just need to test the datapoint alert now in our test environment, but this seems to fit the bill a lot simpler than I was trying to do it, thanks very much :)/emoticons/smile@2x.png 2x" title=":)" width="20" />
·4 years agoJust a recommendation, but why rebuild that datasource? I suggest modifying the discovery script to output an additional instance level property with value 0 or 1 depending on whether or not the description contains the "MO-CRIT" string. This would involve changing one line of code and adding one datapoint.
Using the SNMP_Network_Interfaces datasource, look at line 173 of the discovery script. This line outputs the list of instances:
Remember from AD that there are 5 terms here, divided by ##:
So in this case, we have ifIndex as the wildvalue, "ifEntry.description + [ID:ifIndex]"as the display name, a modified description as the description and we have a list of instance level properties.
Let's look at the instance level properties a little closer:
This is some advanced Groovy syntax, but it basically takes the contents of ifEntry, which is a Groovy Map (similar to Python dict). For one of the interfaces on one of my devices, ifEntry looks like this:
So, the AD script would output something like this for that interface (forgive the horizontal scrolling/carriage return, this is actually one line):
One thing we could do would be to add to this println statement in the AD script to evaluate the description and return a 0 or 1 if the description contains "MO-CRIT". This could be done like this:
This would set an instance level property called auto.interface.alert_on_desc with a value of either 0 or 1.
Then you could create a datapoint called alert_on_desc with ##auto.interface.alert_on_desc## as the infix expression. This will get a 0 or 1 into the datapoint, which could be used in any datapoints that alert to turn the alert on or off.
