Could you please guide me on how I can manage the usage of LM logs?
It appears that our current usage of LogicMonitor logs storage has exceeded the allocated limit of 180GB. How could we address this over usage issue? Do you have ideas on how to prevent this from happening in the future?
tuco
Posted 1 year ago·Last reply 10 months ago
3 comments
Balint Pelhos
·10 months agoThanks patricksites , it helped us.
By default I filter on modules with "Official" support only, and therefore I never found the "LmLogs_Ingestion" datasource by myself. This datasource has the "Community" support tag only, but works properly, it gives back same value as seen on Settings-Usage page.
tuco
OP1 year agoHi Patrick,
Thanks for responding but I would like to know if how can we prevent this from happening in the near future? Your solution is alerting but its not really resolving the issue
Patrick Sites
·1 year agoHi Tuco,
Some LogicMonitor customers have experienced unexpected overage charges related to their contracted monthly LM Logs data ingestion limit and looking for ways to be notified or alerted when/if they exceed a limit or nearing.
Here is the installation process and module information for two new LogicModules that extend the functionality of LogicMonitor Portal Monitoring to include log data ingestion and generate alerts on monthly ingestion contract milestones.
Installation
Module Information
I also suggest using the links to the right of the usage number which resources or resource groups might be your top talkers and use our new LogPatterns feature to narrow in on the noisiest logs and consider filtering those out to reduce some of the noise.
You can read more about Patterns here:
https://www.logicmonitor.com/support/log-patterns
Please reach out to the LM Support team if you need assistance.
Cheers!
Patrick
