Config_Cisco Deprecated Module - Do not Remove
Be careful when removing the deprecated Config_Cisco PropertySource module if you care about keeping your configuration change history.
It uses the same properties as the new Config_Cisco_Generic module and we just lost all our configuration change history because many of devices were using that as the source of the properties which unapplied the property and unapplied the Common ConfigSources.
This will most likely be an issue in the future when they remove the module in a future release so I have a ticket open explaining this and to get my portal restored.
I assume the 2 PropertySources are battling 50/50 to apply their properties so that is why it only affected around half our devices.
Justin Lanoue
Posted 2 years ago
0 comments
