Collectors Capacity review
What are the best reports to be done on collectors to verify their performances?
- CPU
- RAM
- Disk (I/O, Space...)
- Resources #
- Instances #
I attached below the data in the screenshots I am looking to collect in a excel file...
Dom
Dominique
5 comments
Kirby_Narine
Yes, you should leverage the resource metrics trends report.
Report creation: https://www.logicmonitor.com/support/reports/creating-managing-reports/what-are-reports
Resource metric trends report info: https://www.logicmonitor.com/support/reports/report-types/device-metric-trends-report
Use the same datasources you want to pull from in the report. If you have your collectors dynamically grouped, (maybe already in “Devices by Type/Collectors”), you can target that group.
Dominique
OPHello,
Is it possible to have these information in a report instead of dashboards…?
Dom
Kirby_Narine
“Collector Thread: Time” or “Collector Thread: CPU” in your screenshot are good ones as well.
If you see any specific instance spiking (let’s say, batchscript), it means the collector needs more threads put towards that collection method. The threads can be raised in the collector config (colector.batchscript.threadpool is a very common one to raise), but should only be done if the CPU and Memory of the host are not reaching their peak. I’d recommend reaching out to support before making any collector config changes for general guidance.
Collector Data Collecting Tasks (also seen under that collector datasource list in your screenshot) is also very useful. If you see a queue depth (on graph), it might mean the collector is having trouble keeping up with the load.
Dominique
OPDominique
OP
