Availability alarm correlation
When any server is down, I can see alarms reported by Ping and Host Status LogicModules, but I can also see other alarms reporting some missing data.
Is there any method to automatically acknowledge (or tag) those missing data alarms reported when a server is simply down?
It looks like a "Host Status" alarm should silence all other alarms from that server. Should this make sense?
Javier Llorente
1 comment
·5 years agoYes, the Host Status alert should cause the device to be marked as "Dead" which should suppress all other alerts on that device. However, there's often a race condition if other thresholds are set. The Host Status alert threshold is >300 on the idleInterval datapoint. It's definition is:
So, the alert opens at 5 minutes, then the logic kicks in to mark the device as down at 6 minutes. If any alerts open before that, they are not closed, and there was nothing stopping them from opening.
I know there have been a few requests allowing customers to modify the built-in server-side logic that marks a device as dead. I recommend you reach out to your CSM to add your support to that request.
