API Patch for CustomProperties
Hi Guys
I'm trying to write in customproperties to a device as follows:
I can correctly patch the displayname, but the customproperties hastable is not being written. I get a success 200 response back from my invoke-restmethod however.
Ive tried with the customproperties hash table seperate to displayname but i cant get this working.
Does anyone have any ideas on this?
NOTE: xxx is the correct ID
Thanks
$company = 'xxx'
$accessId = 'xxx'
$accessKey = 'xxx
$computername = "$env:COMPUTERNAME"
$httpVerb_04 = 'PATCH'
$resourcePath_04 = "/device/devices/xxx"
$patchfields = '?patchFields=displayName,customproperties&opType=add'
$body = @{
'displayName' = "$computername"
customproperties = @{
name='srv.location'
value='test'
$body = $body | convertto-json
<# Construct URL #>
$url_04 = 'https://' + $company + '.logicmonitor.com/santaba/rest' + $resourcePath_04 + $patchfields
$epoch_04 = [Math]::Round((New-TimeSpan -start (Get-Date -Date "1/1/1970") -end (Get-Date).ToUniversalTime()).TotalMilliseconds)
$requestVars_04 = $httpVerb_04 + $epoch_04 + $body + $resourcePath_04
<# Construct Signature #>
$hmac_04 = New-Object System.Security.Cryptography.HMACSHA256
$hmac_04.Key = [Text.Encoding]::UTF8.GetBytes($accessKey)
$signatureBytes_04 = $hmac_04.ComputeHash([Text.Encoding]::UTF8.GetBytes($requestVars_04))
$signatureHex_04 = [System.BitConverter]::ToString($signatureBytes_04) -replace '-'
$signature_04 = [System.Convert]::ToBase64String([System.Text.Encoding]::UTF8.GetBytes($signatureHex_04.ToLower()))
<# Construct Headers #>
$auth_04 = 'LMv1 ' + $accessId + ':' + $signature_04 + ':' + $epoch_04
$headers_04 = New-Object "System.Collections.Generic.Dictionary[[String],[String]]"
$headers_04.Add("Authorization",$auth_04)
$headers_04.Add("Content-Type",'application/json')
<# Make Request #>
$response_04 = Invoke-RestMethod -Uri $url_04 -Method patch -body $body -Header $headers_04
Ian_Fraser
1 comment
·3 years agoCustom properties needs to be a list of hash tables. Not a single hash table. Be aware, if you do this, you are potentially erasing all other custom properties on the device and replacing with this one. I would fetch the current custom properties, add my property in, then patch the whole thing. Alternatively, you could do a PUT on /device/devices/{deviceId}/properties/{name}, which will ensure you're only touching that one property. PUT will create it if it doesn't exist, update it if it does exist.
Also, I've had inconsistent behavior around the opType query parameter (I also use the SDK a lot and that may be where the inconsistency lies).
