API filter on multiple properties
I'm not seeing any way to return the devices I want, matching two property values.
Using a filter like this works: 'filter=systemProperties.value~"DeviceGroupName"'
But if I want only Exchange servers in the device group: 'filter=systemProperties.value~"DeviceGroupName",systemproperties.value~"Exchange"', does not return fewer devices.
Any way to do this in a single query?
mhashemi
9 comments
·5 years agoAgreed. We need every customer who wants this to request it through their CSM.
This is what i pretty much always do. The only time i put filtering on is to reduce the number of paging calls i have to do.
·5 years agoI think I have just gotten used to full or partial table scans and then run all the complex bits on the client side. Wasteful of resources and more time-intensive, but ya gotta do what ya gotta do.
mhashemi
OP5 years agoThat'd be helpful. :)/emoticons/smile@2x.png 2x" title=":)" width="20" />
·5 years agoSomething that strikes me as I delve into this further is that filter syntax is largely undocumented. There are examples in the legacy docs, nothing really in Swagger. I have figured it out mostly via trial and error and the occasional support ticket. It is clear you can use AND logic with comma-separated components, but is is not clear if you can reference the same LHS multiple times. The is really no indication you can implement OR via filter short of glob expression matching. The only documentation I can find on filters specifically relate to limitations added for embedded special characters in the v2 API. Perhaps the API team could document the various common parameters in Swagger or elsewhere?
mhashemi
OP5 years agoI'm trying to write something that will support various use cases without forcing the user down any particular path. If they want to create a dynamic group, that's fine, but it seems like we oughta be able to support filtering like this without resorting to mucking about in the portal (not everyone has Manage rights either).
·5 years agoSo create a dynamic group under "/Devices by Type" and query that group's membership from the API?
mhashemi
OP5 years agoBecause I don't know where, in the group structure, the Exchange servers are located. For example, "Customer" could have "Location A" and "Location B" subgroups, each of which could have "Linux" and "Exchange" subgroups. Maybe they also have an Exchange server directly in the "Customer" folder. I could recursively search for subgroups, then for each one, use the endpoint you suggested, but that seems inefficient.
This seems to work:
But what if I needed devices (in the CustomerName group) that had "category1" or "category" in system.categories? Both of the following filters returns zero results (in the portal right now, I am looking at one device that should be returned, but maybe there are more):
Incidentally, while thinking of another example, I found that this works to give me 32-bit Windows servers with 3.75GB of memory (across all groups):
·5 years agoWhy not just his this endpoint?
/device/groups/{id}/devices
get immediate devices under group
