An error occurred: JZ006: Caught IOException: java.io.IOException: JZ0EM: End of data.
while @dbid <= @maxdbid
begin
select @dbname=dbname,@logtype = logtype from tempdb..WNLdblist_logsegment where dbid=@dbid
use @dbname
declare @dbsize integer
select db_name() dbname, s.name segname, s.segment, u.segmap,u.size, curunreservedpgs(db_id(), u.lstart, u.unreservedpgs) unreservedpgs
into tempdb..WNLsegments_logsegment
from master..sysusages u, syssegments s
where u.dbid=db_id() and power(2,s.segment) = u.segmap & power(2,s.segment)
order by s.segment
declare @pgsize integer
select @pgsize=low/1024 from master.dbo.spt_values where number = 1 and type = 'E'
select @dbsize=((sum(size)*@pgsize)/1024) from master..sysusages where dbid=@dbid
select top 1 db_id(dbname),dbname as DBNAME,
convert(integer,(sum(size)*@pgsize)/1024) as TOT_SEG_SIZE_MB,
convert(integer,((sum(size)-sum(unreservedpgs))*@pgsize)/1024) as SEG_USED_MB,
convert(integer,(sum(unreservedpgs)*@pgsize)/1024) as SEG_FREE_MB,
convert(integer,100*(sum(size)-sum(unreservedpgs))/sum(size)) as PERCENT_USED_SEG_MB
from tempdb..WNLsegments_logsegment
where segname='logsegment'
group by dbname,segment
order by dbname,segment
set @dbid=@dbid+1
end
def resultSet = sql.rows(query)
// Process the resultSet (e.g., print or do something with the data)
resultSet.each { row ->
//println("DBID: ${row.DBID}")
// println("SYB_INSTANCE: ${row.SYB_INSTANCE}")
println("DBNAME: ${row.DBNAME}")
// println("SEGMENT_NAME: ${row.SEGMENT_NAME}")
// println("LOGTYPE: ${row.LOGTYPE}")
println("TOT_SEG_SIZE_MB: ${row.TOT_SEG_SIZE_MB}")
println("SEG_USED_MB: ${row.SEG_USED_MB}")
println("SEG_FREE_MB: ${row.SEG_FREE_MB}")
println("PERCENT_USED_SEG_MB: ${row.PERCENT_USED_SEG_MB}")
println()
} catch (Exception e) {
// Handle any exceptions that occurred during execution
println("An error occurred: ${e.message}")
e.printStackTrace()
// Drop the table WNLsegments_logsegment if it exists
sql.execute("if exists (select 1 from tempdb..sysobjects where name = 'WNLsegments_logsegment') drop table tempdb..WNLsegments_logsegment")
// Drop the table WNLdblist_logsegment if it exists
sql.execute("if exists (select 1 from tempdb..sysobjects where name = 'WNLdblist_logsegment') drop table tempdb..WNLdblist_logsegment")
// Ensure the SQL connection is closed regardless of success or failure
sql.close()
·3 years agoTo talk in general, I don’t know SQL well, I suggest attempting to troubleshoot your code by temporarily removing parts and attempting to determine exactly which line/statement is causing the error. For example you might want to temporarily remove the try/catch which might help see which specific line is failing, or comment out parts of the code until you find just the lines(s) causing the error.
manthena2020
OP3 years agoi am getting this error.
manthena2020
OP3 years agoimport groovy.sql.Sql
Class.forName("com.sybase.jdbc4.jdbc.SybDriver")
// Get basic info to connect
def hostname = hostProps.get("system.hostname")
def user = hostProps.get("sybase.user")
def pass = hostProps.get("sybase.pass")
def port = 21000
def wildvalue = instanceProps.get("wildvalue")
// Construct an SQL instance with a URL and a driver
def url = "jdbc:sybase:Tds:${hostname}:${port}"
def sql = Sql.newInstance(url, user, pass, "com.sybase.jdbc4.jdbc.SybDriver")
try {
// sql.execute("if exists (select 1 from tempdb..sysobjects where name = 'WNLdblist_logsegment') drop table tempdb..WNLdblist_logsegment")
def query1 = "select dbid, name as dbname, (case when status2 & 32768 = 32768 then 'MIX' else 'SEP' end) as logtype into tempdb..WNLdblist_logsegment from master..sysdatabases where status2 & 16 <> 16"
sql.execute(query1)
def query = """
set nocount on
declare @dbid int,
@maxdbid int,
@dbname varchar(50),
@logtype char(3)
select @dbid=min(dbid),@maxdbid=max(dbid) from tempdb..WNLdblist_logsegment
begin
use @dbname
order by s.segment
set @dbid=@dbid+1
end
println()
e.printStackTrace()
sql.close()
manthena2020
