Alert on changes to Property Values
Has anyone setup a datasource that would send out an alert if specific properties change their value?
A request from our network team is around triggering an alert when the firmware on some devices changes. This is being populated into a property for the device but need a way to trigger an alert when its value changes.
We are migrating from Solarwinds and it seems like this was an ability Solarwinds could alert on.
Jeffrey Batchelor
6 comments
·2 years agoThis is the right way to do it.
Müller_N
·2 years agoUse a script datasource, get the data out of the device property with the
usual hostProperties groovy line like:
Remove any NaN characters or create something like a hash sum and convert it to an integer so LogicMonitor can store it in a datapoint.
Then use the one of the numerous delta functions as a threshold:
Does not sound particularly difficult to me.
Jeffrey Batchelor
OP2 years agoI will try this. Thanks!
sidd_pin
·2 years agoHi Jeff_Batchelor Unfortunately, it is currently not possible to trigger an alert based on a change in a property value.
·2 years agoI'm not aware of a way to alert on a property change directly, but you can create a ConfigSource (if there isn't one already) that contains the firmware version so LM can alert on it changing that way.
Jeffrey Batchelor
OP2 years agoI will look to see about trying to do it this way as it does seem like the only possible solution that doesn't involve a lot of work scripting out a way to read a custom property out into a different custom property and then comparing it to the old one on some basis.
