Alert if other datapoint = x
Hey folks,
I have a custom Powershell script, that effectively returns 2 results.
DaysRemaining
Returns any integer value
This datapoint alerts when there is <=30 days remaining
InUse
Returns Boolean 0/1 (0=not in use / 1=in use).
I am wondering how I can surpess the DaysRemaining alert, when the the "InUse" datapoint returns 0 (not in use)
Any help greatly appreciated.
birchall
2 comments
·2 years agoYou can use Complex Datapoints that has an IF expression that can return a different value depending on the InUse state. You would then setup thresholds on this datapoint instead of the original DaysRemaining. There are several built-in Datasources that do this, like AWS_EC2 and AWS_Connect.
So something like this (did not test): if(eq(InUse,1),DaysRemaining,unkn()) , which you can then name "DaysRemainingIfInUse" or the like.
birchall
OP2 years agoThat has worked a treat thank you very much
