Advice on dashboard sources
Hello
Have not yet been on the dash boarding training so please bear with ?
I have some data stored in a SQL server which I would like to display on an LM dashboard. I would like
various controls such as pie charts and tables that all operate on the same parameters (From and To dates) with some defaults
such as 7 days ago to yesterday.
I was wondering if I should plug this in via a Groovy script pulling data from views and/or stored procs or whether I should
go via something like PowerBI gateway.
Not looking to re-invent the wheel, just get some summary data into a dashboard.
Thanks
david_gray
3 comments
Ah, yes. Sorry, I jumped to the wrong conclusion.
You'll need to build custom JDBC datasources that pull your data into LM. Then building the dashboard is possible. Details: https://www.logicmonitor.com/support/logicmodules/datasources/data-collection-methods/jdbc-data-collection
david_gray
OPHello
Our built-in SQL dashboard uses the LM metrics which is fine for monitoring SQL servers, however I want to pull data out of SQL tables, views and procedures into
dashboard widgets. The data pulled from other systems APIs and stored for reporting. Two separate things I think?
Thanks
Check if the built in datasources have the data you need. Then take a look at the built in SQL dashboard. All dashboards have the date mechanics you mention.
