UIv4 Alert Tuning
UIv4 alert tuning is a great improvement over UIv3 because of the ability to filter by DS name. It's the only piece of UIv4 that I choose to use over UIv3. However, there is still a big problem with it:
DS name != DS name.
Every DS has two names, the name and the display name. The name must be unique and usually is one word (though interestingly doesn't have to be). The display name does not have to be unique. This is a good thing because some DSs while having different names and gathering data differently represent the same family of data. Count how many DSs are for CPU. It's nice that they can all share the same name (though because of development happening across years/decades with different developers it isn't consistently done. I'm ranting; back on topic...)
When you search for a datasource, you cannot search by unique name, but only by display name. So if you want to modify a threshold for one datasource and there are two others with the same display name, it can be really difficult to tell which datasource you're editing.
Consider this case: I need to modify the thresholds for VMware_vCenter_VMSnapshots. Which one is it? Hint: the other is "VMware_vSphere_VMSnapshots". Can you tell which is which?
LM:
- Give us the option to display the module's unique name in the table
- Give us a checkbox that will turn on display of the module's unique name in the search results. Those who don't care won't turn it on, but for those who do we can turn it on and not have to guess which module we're customizing thresholds for.
Barb Ramirez
·2 years agoAlso there is no ability to see which is a disabled Datasource.
Michael Rodrigues
·2 years agoFor what it is worth, this field has been more appropriately named "resources label" to avoid further confusion that has arisen from it being called "display name".
David Bond
·2 years agoWe would also very much like to be able to filter alerts (in our case via the API) on the unique datasource name or id.
The same goes for all locations in the resource tree: Tenant, ResourceGroup.id/fullPath (with or without descendants), Resource, ResourceDataSource, ResourceDataSourceInstanceGroup, ResourceDataSourceInstance, ResourceDataSourceInstanceDataPoint.
While we're at it, being able to filter within ranges for the alert start time and end time would be good too, so I can find alerts that started last calendar month and ended this calendar month for reporting purposes.
Hmmm... can we gather a focus group here?
OP2 years agoSuper like!
OP2 years agoWhile we're at it, when setting a static threshold somewhere other than the module, we have the ability to set the no data, alert trigger interval, and alert clear interval. This is fantastic, but there's no "inherit from parent" option.
