Zerto JobStats
<span class="pln">Good Morning All,
For anyone looking to monitor Zerto replication jobs via LogicMonitor we have this PowerShell based batchscript datasource. I hope you find it useful; 6477DR from the LM Exchange.
These are the collected data points:
ActualRPO
IOPS
LogicMonitorScriptTime
Priority
ProtectedEntities
ProvisionedStorageInMB
RecoveryEntities
SourceEntities
Status
SubStatus
TargetEntities
UsedStorageInMB
These are the calculated data points based upon those collected:
ProvisionedStorageInGB
UsedStorageInGB
Please respond with any questions.
Respectfully,
Alejandro Esmael</span>
Alejandro_Esmae
7 comments
James_Rolt
Have you got the details on how you modified this to report on the VPG instead please?
Thank you,
James
Joe Williams
Go into Datasources -> Add -> From LogicModule Exchange. Type in that code.
Naim_Aliu
I don't think i know what LM Exchange is. Can you elaborate a little bit? Thanks!
Joe Williams
Use the 6477DR code in the LM Exchange. It pulls everything down. I used it and heavily modified it to monitor via VPG instead of VM as each VM is forced to have the same RPO/Status.
Naim_Aliu
Was this ever tested? I can't seem to find the datasource in LM
B_Schlegel
I'd be interested in this as well
Marco_Sal
Where can I find this Powershell script? Interested in giving it a try.
Marco
