NetApp Cluster Health
We found out the hard way this past weekend that the current NetApp DS suite is missing a crucial check for cluster member health. You can deploy it from here (once the code is reviewed -- hopefully quickly as it is just a clone with a different query and datapoint set).
FJTRGL
6 comments
·6 years agothanks @Michael Rodrigues, i hadn't gotten to doing the diff yet.
Michael Rodrigues
·6 years agoThanks @mnagel, sorry you got burned by this. We've got a ticket in to the MOD team to fix this.
·6 years agoCool, i'll do a diff as soon as i get a chance so i can open the ticket. Also, you can insert a code snippet right in this post (not attachment) using the "<>" button in the toolbar.
OP6 years agoFWIW, this has no graphs defined, which may be desired. I was dealing with a bit of a fire drill at the time. That said, all the DPs are boolean, so not that big of a problem.
OP6 years agoCan't attach XML or even text, but there's more than one way to do it :).
https://www.willingminds.com/sites/default/files/NetApp_Cluster_Health.txt
Thanks, Mark
·6 years agoIf you don't mind, can you post your change here (screenshot or xml)? I can open up the ticket to get it fixed faster than it will get approved.
