Datapoints configuration Discussion
Hello Team, I am trying to create a custom datasource to check the service status. It retrieves a list of services from the host properties(auto.service.names), connects to the host using SSH, checks the status of each service using the systemctl command, and outputs the results.
Active Discovery Script:
import org.xbill.DNS.*;
// Get the service names from the host property
def serviceNames = hostProps.get("auto.service.names") ?: ""
def serviceArray = serviceNames.split(",").collect { it.trim() }
// SSH details for connecting to the host
host = hostProps.get("system.hostname")
user = hostProps.get("ssh.user")
pass = hostProps.get("ssh.pass")
port = hostProps.get("ssh.port")?.toInteger() ?: 22
cert = hostProps.get("ssh.cert") ?: '~/.ssh/id_rsa'
timeout = 15000 // Timeout in milliseconds
// Initialize JSCH for SSH connection
import com.jcraft.jsch.JSch
def getServiceStatus(serviceName) {
def command = "systemctl is-active ${serviceName}"
return getCommandOutput(command).trim()
def getCommandOutput(String input_command) {
def output = ""
def session = null
def channel = null
try {
def jsch = new JSch()
if (user && !pass) {
jsch.addIdentity(cert)
session = jsch.getSession(user, host, port)
session.setConfig("StrictHostKeyChecking", "no")
session.setTimeout(timeout)
if (pass) {
session.setPassword(pass)
session.connect()
channel = session.openChannel("exec")
channel.setCommand(input_command)
def commandOutput = channel.getInputStream()
channel.connect()
output = commandOutput.text
} finally {
if (channel) {
channel.disconnect()
if (session) {
session.disconnect()
return output
// Output each service with its status
serviceArray.each { serviceName ->
def status = getServiceStatus(serviceName)
println "${serviceName}##${serviceName}##Status: ${status}"
return 0
Collection Script:
Below, I am trying to use the ##WILDVALUE## from the active discovery script to collect the service status value.
com.jcraft.jsch.JSch // Initialize JSCH for SSH connection
// Function to retrieve the service status
def result = getCommandOutput(command)
return result?.trim()
// Function to execute command and retrieve output
def getCommandOutput(String command) {
def output = ""
def session = null
def channel = null
def reader = null
try {
if (pass) {
session.connect()
channel.setCommand(command)
channel.setInputStream(null)
channel.setErrStream(System.err)
reader = new BufferedReader(new InputStreamReader(channel.getInputStream()))
channel.connect()
def line
while ((line = reader.readLine()) != null) {
output += line + "\n"
// Ensuring the channel finishes before disconnecting
while (!channel.isClosed()) {
Thread.sleep(100)
} catch (Exception e) {
println "Error executing command: ${e.message}"
} finally {
reader?.close()
channel?.disconnect()
session?.disconnect()
return output
// Retrieve the current service name based on ##WILDVALUE##
def serviceName = datasourceinstanceProps.values().collect { it.wildvalue }.find { it != null }
if (serviceName) {
def statusValue = (status == "active") ? 1 : 0
println "Service:${serviceName} Status:${statusValue}"
return statusValue
} else {
println "Error: No service name found for ##WILDVALUE##."
return null
I need help creating the datapoint to collect service status value. Thanks in advance.
The error I am currently getting:
·1 year agoIs this a "SCRIPT" or "BATCHSCRIPT" type of DataSource? What is the Datapoint's "Interpret output with" set to?
There is likely a specific format you need to output your Collection Script. I didn't look at your code too closely but if your using BatchScript you likely want to use something like this for the output:
