Virtual Datapoints in Tables (Dashboards and/or Reports)
It would be great if we could get virtual datapoints in tables within a dashboard and/or report. We use virtual datapoints for things such as an interface's 95th percentile or to calculate the amount of data an interface has done over a period of time and the datapoint is a single calculated value over that period of time so a graph is not required.
JayLe
2 comments
JayLe
OP5 years agoWe need to be able to do it for a top 10 table where there may be 100s of instances. When using Sum / aggregation reports it aggregates all instance values.
·5 years agoFor that specific example, you can do a sum aggregation in the report, which would give you the total over the report period.
