Native Support for GB and TB When Reporting on Volume Capacity
While getting a Metric Explorer report together is easy enough to report on the Volume capacity, the fact that the Capacity, Free Space, and Usage fields are in bytes instead of Gigabytes or Terabytes make it hard for users to accurately depict the amount of storage that is being reported on.
Yes you can export it as a CSV and use a formula to get the values in GB or TB format, but adds additional steps and adds user error.
This is a basic feature that I'm surprised isn't already implemented in such a robust product.
Matthew Bashore
Posted 2 weeks ago ยท Edited 2 weeks ago
0 comments
