Monitoring Linux systems using SSH
On 4/18/2020 at 2:55 PM, raul.rtr said:So with current SSH based Linux datasources we miss important required capabilities:
- Linux text log monitoring: Basically, we need to be able to monitor specific log files in a target server for the appearance of specific error patterns on them, and raise an alert in case any of this error occurs. The rule to trigger the alarm must manage the triggering of the alarm depending on the recurrence of the errors and probably other rules. The datasource should be able to manage checkpoints in order to be aware what was the last log line read ensuring that always read only new content in monitored files.
- OS process monitoring: we need to be able to monitor the presence of OS processes and if the number of processes instances required are in execution and probably other rules.
I suggest you start a new thread/topic. You can also try taking one of the existing linux ssh DataSources and customizing the Groovy code to do the work you need.
·6 years agoThis thread was split from here. @raul.rtr, tagging you for visibility. You said:
You would accomplish this via a custom EventSource.
You can do this with a custom Groovy based Datasource making use of the Expect library built into the collector.
