LM Dashboards filter by property
LogicMonitor dashboards are powerful, especially with tokens. One huge/valuable addition (especially for a Managed Service Provider) would be a token to filter for specific instance group. IE a token for #defaultinstancegroup#. You can go into an instance today and clone a graph and it will show it’s setup for the instance group, but you can’t edit that or use that across a dashboard or create a widget by instance group. Similarly, would be great to have a token that could filter a dashboard by property; ie default resource pool.
Stephan Cico
2 comments
AustinC
·3 years agoIt seems this is an oft-repeated ask of LogicMonitor, going many years back. I, too, desperately need additional filtering capabilities on Dashboards so that I can expose better self-service functionality to my users.
I severely hope that LogicMonitor is gearing up to give Dashboards a _desperately_ needed make over so that they can finally achieve parity with competition in the market today. Present Dashboard functionality quite simply isn’t scalable -- Instance-Level property filtering + having some sort of functional drop down for changing group/resource/instance tokens on the fly on a per-user basis (i.e. not affecting the dashboard) are two of the largest asks our organization has had for the past 3 years.
Here’s hoping Product can make these happen 🤞
·3 years ago+1e100
