File Size and Folder Monitor.
Hi All. I believe LM is missing an officially supported WinTel File and Directory management DS. It should include the following
File Count Monitor to count the number of files in a folder
File Size Monitor , aggregate of all files.
Last modified
File Exists
An example that would use all the functions would be something like Clearswift/MimeSweeper. An Internet facing Email gateway appliance. You would have incoming and outgoing folders as well as Quarantine and Delayed. The Folders selected need to be added via a 'monitored instance' leaving the original DS untouched.
Andy_C
1 comment
Jared Meidal
Have you tried the UNC Monitor module? It works for our scenarios of gathering:
