Feature Request: Modules for Cisco ISE Data Connect
Since upgrading to Cisco ISE 3.2 there has been a new feature added called "Data Connect" According to Cisco, "The Data Connect feature provides direct access to the Cisco Identity Services Engine (Cisco ISE) database so that you can query Cisco ISE data and create your own reports. You only have read-only access to the data. The Data Connect feature is supported from Cisco ISE Release 3.2."
"You can extract any configuration or operational data about your network depending on your business requirement and use it to generate insightful reports and dashboards."
https://developer.cisco.com/docs/dataconnect/
I know that LogicMonitor can collect data via JDBC and i think this would be a huge benefit to those wanting to monitor their ISE environment that are on version 3.2+
Sky Donnell
Admin11 months agoHey Devin, I've sent this over to the Product team as a feature request! Thanks
