Extreme Networks EXOS ConfigSource
Please add a ConfigSource for Extreme Networks EXOS devices! It appears to be one of the only pretty large vendors that doesn't have a ConfigSource created yet. We have quite a few customers with a good amount of EXOS in their environments that I would love to back up using LM!
Thank you!
dlebouef
1 comment
·4 years agoHave you tried writing the configsource yourself? If you know the commands required to display the config after logging into the device via SSH, it should take too much. Similar to this or this, just substitute the command(s) to execute. For configsources, all you need to do is have your script fetch the config (however you want to do that), then print the config to the screen. Your config checks then take care of alerting on the circumstances you define.
