Dependent Alert Mapping - reviewing cleared alerts
I recently had an LM support ticket open for some confusion we had around the Dependent Alert Mapping feature. Wanted to document some areas for improvement here that would make the feature work better.
- Currently, when an alert clears which was processed by Dependent Alert Mapping, the "Routing State" and "Dependency Role" columns set to blank. This makes it challenging to go back and review alerts after an outage to see what was "Originating" vs "Dependent"
- Please update the feature so that these columns on the alert table are still populated after an alert clears. This will help us with reviewing and reporting on resolved outages
- Currently when an alert is suppressed by dependent alert mapping, the alert message contains a lot of useful metadata related to the alert suppression. But if the originating alert clears and the dependent alert is still active, all of that metadata is removed and there is no indication that the alert was ever suppressed by the Dependent Alert Mapping feature
- This causes confusion when we go back to review past outages. It makes it look like the feature did not work as intended, even if it did. Fixing this along with item #1 would make the feature a lot easier for us to use and understand what it is doing.
Matt Whitney
Posted 1 year ago·Last reply 9 months ago
6 comments
Andy_C
·9 months agoTaking on my 2c, perhaps a way to "replay the events" from the audit logs as the Root Cause shifts back and forth as to where LM believes the current RCA is.
Dave Lee
·9 months ago+1
We've started using this feature as well and come to the same conclusion. While it works really well, it is quite difficult to analyse what happened after things clear because key fields that show why an alert was suppressed get cleared.
It does describe the behaviour on this page in the documentation: Enabling Dependent Alert Mapping | LogicMonitor
Note: The values reported in the Dependent Alert Mapping columns will only display when an alert is active. Once it clears, the values within the column will clear, while the original Dependent Alert Mapping metadata will remain in the original alert message.
Although it's clearly been implemented this way by design, I can't understand why you would want to remove data that would be useful for retrospective analysis.
Matt Whitney
OP1 year agoThanks! I wouldn't really call this a feature request in my opinion though. This is more of a bug that makes the feature difficult to use/troubleshoot after alerts have cleared. I feel like most feature requests end up getting ignored, so would appreciate if this was treated with more urgency. Would be happy to get on a call with the product team to explain why its important.
