Ability to set # of consecutive polls for a certain DS (on a group/client basis)
This request might not be that easy to achieve, but, it would be very very helpful if we could select/tweak the # consecutive polls to alarm for a certain data point (according to each client necessity) without having to create a NEW DS for each scenario.
Not sure if someone brought that in the past already, this a feature we're losing when moving from our old platform & would be extremely appreciated.
Essentially we just want to be able to have the WinCPU (for example) with its GLOBAL definitions. But, if Client A requests to alarm on CPU after 3 consecutive polls (different from the GLOBAL) & Client B wants it 10 consecutive polls, we need to be able to achieve it without having to create a DS for each requirement.
Thank you!
Regards,
·5 years agoWith the exchange, there's a possibility of maintaining multiple children DSs for a single parent DS in the repo. With that, you'd be able to clone an existing repo module, modify it and both the original and the clone would subscribe to the in repo version for updates. It's a possibility now that we have exchange rolled out. not sure if/when.
muiz
·5 years agothis is also how one of our old monitoring tools, CA Performance Management (and CA eHealth before that) used to do - calculate over time instead of consecutive polls. that way occassional spikes are ignored but picked up issues if spikes are frequent.
e.g. if utilization value is above threshold for 30min out of 1 hour window (fixed or sliding etc.), then generate alarm.
Dynamic thresholds in LM can somewhat cover for this, i think, but still not as flexible as defining our own 'threshold violation duration' in a 'specified window'
Vitor_Santos
OP5 years agoYes, creating new DS isn't an optimal/acceptable solution exactly due to that. We need to maintain each DS & if there's a new one released we would need to edit all the other ones to keep everything according...
There should just be a way of tweaking this & still maintaining the parent DS.
