What is best way to optimized Logic Module in Largescale environment?
Suppose a LogicModule is monitoring 10,000+ devices and uses Active Discovery with a script-based Data Source. The discovery process suddenly starts consuming high Collector CPU, while some instances are intermittently disappearing and reappearing. How would you troubleshoot this and what is best way to optimized logic Module in large scale environment?
SUYASH GAIKWAD
Posted 1 month ago · Edited 1 month ago·Last reply 1 month ago
1 comment
Ben Tan
·1 month agoCheck that collector status as well as confirm it is sized correctly and probably create an ABC group
