show next dashboard after: x seconds
It would be pretty cool if we had the option to show dashboard one for 30 seconds and then show dashboard two for 15 seconds and then dashboard three for 15 seconds.
mkerfoot
2 comments
Mosh
@mkerfoot If you use Chrome this might help. We use this Chrome extension which lets you choose a different timeout for each URL.
https://chrome.google.com/webstore/detail/rotisserie-url-rotator/iljemanjjfjlglhkmojkmfbpphiaheja?hl=en
If you didn't know, you can use the slideshow option to cycle thru a list of dashboards. It uses a fixed time for all the dashboards (so can't be 30s then 15s then 15s, but a fix 15s or 30s per dashboard works. I guess you can cheat and setup 15s cycle then have two identical dashboards to make it look like it's shown for 30sec. Slideshow doesn't seem to let you pick the same dashboard twice.
