Self-Healing actions
Previously I used to work with Solarwinds N-Able as a primary monitoring solution but one of the major features I miss in LM is simply self-healing actions. For example if we have some generic alert, we can automatically run a scripted solution in order to resolve the alert which is incredibly handy and adds lots of value to a monitoring system.
This is useful in certain events where in response to a specific alert there is always a pre-defined action to take which generally doesn't change and if it does can be managed via SCM/ConfigMgmt.
Imaginovskiy
1 comment
Mosh
Just a suggestion, Jenkins has a really good REST API which can be used to trigger task automations. Could use the LogicMonitor generic HTTP integration to trigger a Jenkins task.
