REST API - Devices associated with DataSources
I'm currently working on a project to validate any configured LM alerts have an associated documentation - our documentation should have the datasource name as part of the title. Furthermore, I need to filter out devices that are not in my team's escalation path/rule. e.x. filter out "dev" environment devices.
- I'm pulling a list of datasources using the REST API '/setting/datasources' endpoint.
- I use a filter to only grab those that match my team's given escalation path/rule.
- I then pull the datasource properties, specifically the "appliesTo" value in the json response.
- I'm then converting those values into filters that can be used on the 'getDevices' REST API endpoint
Is there an easier and/or better way to match datasources back to devices? The 'appliesTo' values returned do not use the same structure and naming convention used with the 'getDevices' filters.
msterry
2 comments
msterry
OP8 years agoI'm ashamed I didn't see that sooner. Thank you so much!
Sarah_Terry
·8 years agoThere is, actually! There is a sub-resource of the datasources resource for associated devices: /setting/datasources/{id}/devices. I've added it to the documentation here: https://www.logicmonitor.com/support/rest-api-developers-guide/datasources/get-datasources/
