Report for Unmonitored Instances
Looking for a way to generate a daily report for instances that are in the Unmonitored Group. By default, we place new instances in that group and need a mechanism to identify those on a daily basis.
Grant
2 comments
Justin
·8 years agoWhat I would like is to just have the list of devices found during a NetScan attached to the email that it sends out. Or the above! something...
Jeffrey_McGover
·8 years agoHey Grant,
Have you figured out how to do this? Probably not the most elegant solution to the problem because it will most likely involve changing existing process but a way to solve this would be to create a device group (something like _implementation_) and then using Advanced Netscan dump all new assets into this group rather than unmonitored. This would then allow you to run a standard device inventory report against that group. Not elegant but would get you from here to there.
The only other thing I can think of would be to submit a Feature Request to be able to add a customer property to the unmonitored group that you could pick up with the reporting engine.
