Polling devices that don't ping
I have a few devices that, for some reason, do not respond to ping; is there a way to bypass the Ping check to query/discover these systems?
Dan_Wood
Posted 8 years ago·Last reply 7 years ago
4 comments
Mosh
·7 years agoI've used CSV in the past to do initial uploads and it always did the active discovery. As Chris suggests, try some manual active discovery and datasource force match.
chris8777585
·7 years agoHave you tried running active discovery from the device then re matching the datasources.
Dan_Wood
OP8 years agoThese are added via CSV and harvested from another monitoring system; I've verified that I can access the services (e.g. https, snmp) from the collector, but Logicmonitor's isn't initiating an active discovery.
Mosh
·8 years agoHi @Dan_Wood
Are you using the Wizard mode to add them, or the Expert mode? Expert mode would bypass the test. Note, however, without some other type of poll to generate some data, LogicMonitor's Host Status monitoring will generate an alert if no data is received for the device.
