Nodata alerts for common(shared) NFS mount points for individual node.
As you know that NFS mount points are common for all the nodes if you do globally alert for Nodata, alerts will flood, so currently there is no option for alerting Nodata for the individual node. please consider this has product feature request and provide ASAP.
Thanks
Adi
Adhi
1 comment
Joe_Tran
·8 years agoSounds a good use case for defining a cluster alert.
You would still need to set the global datasource definition to alert on no data. Your host cluster alert definition can control if individual node/device alerts will trigger alert actions. Works best if all NFS mounts are from the same source.
https://www.logicmonitor.com/support/devices/device-groups/cluster-alerts/
