Netflow Data Questions
On the netflow tab, it gives the last hour of top talkers/applications. Is there an ability to select the time? For example maybe 2 hours ago or 10 days ago?
Zhi_Yang
Posted 11 years ago·Last reply 11 years ago
2 comments
Joseph_Skupniew
·11 years agoFrom client:rn rnThanks! Didnt realized; was still using the old UI.rnOn the flows, is it possible to change it from bytes to something more readable like Mbytes or Kbytes depending on the amount? Is this coming in a future release?
Annie_Dunham
·11 years agoCheck out the Network Traffic tab in the new UI. Not only do you get much more functionality (and the oft requested pie graphs), you can set your time range.
