Huawei Access Controller / Wireless LAN Controller
Quite new to creating DataSources, but these are a reasonable starting point for anyone with Huawei Access Controllers
WFFGFN - Access Controller
- CPU Used Percent
- Memory Free Percent
- Memory Used Percent
- Memory Free in Megabytes
- Memory Used in Megabytes
HPAF9X - Access Points
- Status codes – Instance Graph
- AP alert - (If Status code = 8(normal) or 11(standby), return 1, is anything else return 0) – Instance Graph- Alert on 0
- Client count per AP – Instance Graph
- Client count Top AP – Overview Graph
- Client count aggregate for whole controller – Overview Graph
- Discovered Property - Mac address
- Discovered Property - Serial Number
- Discovered Property - Model Number
G627K2 – Access Point Radios
- Working channel – Instance Graph
- Client count per radio – Instance Graph
- Channel utilisation – Instance Graph
- Radio status – Instance Graph- Alert on 2(Down)
- Radio throughput in Mbps – Instance Graph
- Top Radio Throughput – Overview Graph
- Radio Work Mode
drazzopardi
1 comment
drazzopardi
OP7 years ago@Andrey Kitsen Tagging as requested
