Flexible SDT configurations
Lets start with an example, I have a router which has many ports and I want to put some ports to SDT. I have 2 options, put SDT port by port or put SDT on whole group and remove some ports from it. Current logic is: choose a device and apply what do you want with it. It'll be good to have it somehow (ie clicking tree-structure) other way around - first I choose what I want to do and after I select where to apply it. It can speed up some tasks...
Petr
1 comment
Mosh
Yes, it would be good to be able to create and manage a library of standard reusable SDT definitions in Settings, rather like AppliesTo functions, and have the option to adhoc apply a standard SDT from the library, overriding any instance or group level SDTs.
